Old 24 Dec 2008, 04:02 am
2007's Avatar
2007 2007 is offline
Default Re: How to: 2007 stereo removal and dash speaker install.
The dash just snaps back into place. Make sure to pull the rubber door gasket from behind the plastic dash after you install it.
Be sure to get these tabs into the dash properly, then snap the pillar cover back into place.
Now on the stereo removal.
There are two screws that need removed, one in the bottom of each vent. Rotate the vents until you can see the screws. Don't let them drop into the duct work!
The panel is held to the dash with clips. Just pull the panel from the dash and remove the wiring connectors for the clock and power windows.
There is a tab that you need to squeeze to remove the connector for the clock.
This is the connector for the window switches. First you need to use a screwdriver and lift up on the red tab to unlock it. Then squeeze the black tab and pull the connector out.
