Thread: Window problems
Old 04 Jan 2009, 10:10 pm
turbozak turbozak is offline
Default Re: Window problems
Yes I had the same problem , the battery died, and I needed to jump start the car.
When I went to open the windows the windows where not working and the power top would not come down. The smart windows got a glitch, no you may not need to go to the dealer for them to reset it.
This is what I did with some experimenting.
1) First charge your battery in the car,
2) disconnect the battery lead to the battery
3) while waiting 5 minutes clean your terminals on battery
4) check your fluids, tire pressure and filter Just for the heck of it
5) reconnect terminals on your battery
6) get in car and gently close the door, the window as you know will be up to high, but this will trick your smart windows to think its in normal position with the door close
7) start your car and hopefully it as booted up to normal.
I did find the first time I did disconnect the battery for a few seconds , this did not work,
it did not clear the memory out of the system.
The other thing was the when I waited 5 minutes the radio station memory was not lost.
Don't rush it,
Good luck and please give me some feed back.
When connecting the battery make sure the doors are closed..
