Old 10 Jan 2009, 10:28 am
CREWZIN CREWZIN is offline
Default Re: Slow leak problem
Lots of owners have the same problem. So far the only way I've heard to stop the leaking is to have a good tire shop take all the tires off and clean the inside of the rim of all the rust and debris so there's good contact for the tire. You might try all new valve stems (just in case) and have the tire shop use some sealer on the edge of the rim when the tires are re-mounted.
