Re: key???
Same here! I had the hardware store cut an extra key, just in case I locked myself out. But, it won't satrt the car. As a matter of fact, it sets off my alarm, until I programmed put the key in the ignition.
*My guess is, that your command start keyfob must be still electronically coded. That means that you can program an extra keyfob, once. You simply need to start the process with the keyfob that is already programmed.
Frank, aka SOONERCRUISER,
