Old 04 Jun 2003, 11:39 pm
yellowpanel yellowpanel is offline
Hi Steve
Your problem is that there is no switch to turn on. Cruisers with factory installed fog lamps have a different signal-headlamp switch then Cruisers without fog lamps. You will need to find the wire coming from the front of the car that does the foglamps and wire it to a switch or replace the signal-headlamp switch with one that has the foglamp function. I'm not sure if the wiring that you found goes all the way to the steering column but it is likely. Be careful not to poke around the Airbag wiring. Deploying the airbag by mistake would ruin your day.
mike@trickcruiser.com
www.trickcruiser.com
