Old 16 Jan 2009, 12:16 pm
Cal Cruzer Cal Cruzer is offline
Default Re: stage one burning my sensors ?
What color was the fluid? Do you have an auto or manual? If the liquid is clear and you have a manual it is brake fluid from either the clutch or brake reservior probably. If it is red it is ATF and I am not sure how it got there. Either way I am not sure how the S1 would burn out sensors. Going over the various sensors in my head they pretty much just send a signal one way TO the PCM. The PCM then tells other components what to do based on that info and calculations. You have something else going on. It would help to identify the sensors replaced.
