Old 20 Jan 2009, 08:21 am
CREWZIN CREWZIN is offline
Default Re: HEADLIGHTS WONT TURN ON
Don't forget, we're only guessing at this point but most of the problems with lights do turn out to be from the multi-function stalk. Don't forget to check the fuses.
The multifunction switch isn't that bad. Somewhere in the range of $75. If you buy one, make sure you get the one that is made for fog lights (if you have the OEM lights). It is made differently. The stalk is replaced easily and can save a bunch on labor charges. One small piece from the old stalk is saved and placed on the new stalk. a couple of wire clips, some screws to work with, panel to replace and your done.
