Thread: without one...
Old 21 Jan 2009, 02:27 pm
nevinsrt's Avatar
nevinsrt nevinsrt is offline
Default Re: without one...
Originally Posted by superpug666 View Post
Hi, i was wodnering if you can feel a power change , with the seat of your pants test, when you take the muffler out? Is it that loud, or like a srt4?
Thanks!
when you delete just the muffler it becomes as loud as a stock SRT-4, which isnt that loud.
it does spool a little faster with it deleted.
when you do a cat delete or downpipe and remove the resignators then it becomes a little bit louder then a stock SRT-4 but not by much.
i can get vid of a stock exhaust SRT and my wifes cruiser side by side this weekend if i remember. all she has is a 3in DP and stright pipe. not loud. now my side exit 3 in stright pipe exhaust on my SRT is loud.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
