Old 21 Jan 2009, 10:17 pm
Franksredpt Franksredpt is offline
Default Re: What's the dumbest thing you've done in or to your PT?
Originally Posted by Hooligan View Post
Instead of starting my 2002, I decided to just push it back in the driveway. Well, it rolled back to far and hit the support for the carport, bent it and warped the door. Had to replace the support and later traded the 2002 in for the 2006.
That sounds almost like what I did. Car was in the garage. Daughter and I got in and she wanted to see the neon lights I had just installed under the seats. I turned them on for just a minute. Then I started the car and proceeded to back up. Only problem is that I never raised the garage door. Bent the garage door panel. Panel not made anymore; had to replace the whole door plus the one on the other side of the garage. Also cracked the clear coat on the bumper.
