Old 23 Jan 2009, 12:05 pm
CREWZIN CREWZIN is offline
Default Re: PT Died going around corner
Originally Posted by crusierdad76 View Post
well at 116000 if you have not had the timing belt replaced then that is what i would say it was.
as far as the oil usage if you run 4000 miles between a oil change and are not using any oil in them 4000 miles that is great I change mine at 3000 and it is never low.
He changes it at 4K but he was over 2 quarts low! He knew he had "oil consumption" but still went 4200K before checking it.
I don't think a head gasket would do what you explained, I am guessing there is no check engine light???
Good question.
