Old 24 Jan 2009, 01:35 pm
ma79915 ma79915 is offline
Default Re: I'll stick my neck out...
Im new to this forum and i have a question about the exact same problem if there is no spark in cylinders #2 and #3 but there is spark in #1 and #4 the ignition coil is good because i checked it the ignition coil harness runs from the coil to the ecm and the only two cylinders that are affected run the same wire to the ecm the ecm should be to blame ?? its 2005 pt cruiser 2.4 turbo
