Old 25 Jan 2009, 06:24 pm
CREWZIN CREWZIN is offline
Default Re: Radiator drain plug
Mapper,
Sounds like your doing a great job of Preventative Maintenance. If I may suggest. The tranny fluid change. If you haven't done it before then I would suggest a flush rather than the pan drop and filter change. Your only getting about a 4 quart change with the pan drop whereas your around 14 quarts with the flush because you get all the fluid. The 41te transaxle isn't the best thing anybody ever made so spending some more $$ on the whole change could make a big difference in the life of it. It's not a do-it-yourself job but well worth it.
On the plugs and wire change. There's a great guide that we put in as a stick on the "Tech and Performance " part of the forum (the part we are in now). It's for the plug change of a 2001 so if yours is a different year just forget abut the EGR pipe that it talks about. It's really not hard to do.
