Old 26 Jan 2009, 01:49 am
cdd's Avatar
cdd cdd is offline
Default 1/4 mile cockpit video
My 14.183 at 95.79 run.
My gauges from top to bottom;
1) pulse width
2) boost
3) engine coolant temp
4) air inlet temp (up cold pipe)
5) knock
6) o2
The green light to the left of the btdc gauge comes on with w/i motor. If knock is present the kr/o2 gauge will flash brighter than normal.
The wide band is on the steering wheel housing and the sensor is currently after the cat.
4shared.com - online file sharing and storage - download 14.183 at 95.79.MOV
2004 PT PLATINUM Lite
Auto | S1 | S2 injectors | K&N FIPK | Hexalogger | S2 wastegate controlled by PCM | 3"o2 | 3"cat | 3"DP | 2 1/4"catback | plastic intake | W/I | DSP Nemo/MM tune | Black ES MM Inserts |
13.89@100.96(1/2 tank E40 fuel, w/i, back seats and spare out, 17" street tires, DSP controlling S2 wastegate)
