Re: One more try... Cruise control not working...
If you double checked everything, the bad news is that part of the computer (PCM/ECM ?) does play a factor in the operation. Have you tried disconnecting the negative battery cable for about 5 minutes since you had the problem with the cruise? It resets a lot of things and just maybe might help.
