Old 28 Jan 2009, 03:27 pm
Mean Green Mean Green is offline
Default Re: Lower engine mount
Originally Posted by ejacko View Post
Hi Everybody
I need some advice on replacing the upper and lower engine mounts. Is there a certain sequence to follow? I don't want to disturb anything I don't have to. I have a 2001, with 76K on it. I appreciate any help I can get.
Thanks, Ed
Be sure to support the engine with a jack with a piece of wood between the jack and the engine so as not to damage anything. The jack will keep the engine from moving around and causing you to have to realign it. Do the motor mounts one at a time. Do the top one first. If you haven't purchased the mounts yet don't use the stock ones. They are too flimsy. You can use the upper and lower mounts for the Neon SRT-4 as they are a lot stronger and are interchangeable with the PT.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
