Old 29 Jan 2009, 05:44 pm
SoCalCruiser's Avatar
SoCalCruiser SoCalCruiser is offline
Default Re: My O6 L.E. Screaming like a Banshee....
There was a leak coming from the neck of the housing. I'm guessing it was the thermostat seal that was out. Even if i ran it for 5 minutes it would start leaking and after a few minutes it would squeal. After i replaced everything and dried it all off..it fine. I was able to smell the antifreeze burning before. The belt still looked good, no cracks or anything on it, it was just wet from the antifreeze. Since i purchased the belt and it only cost me around $12 i replaced it anyway. Heck i had it up on the jack and dissasembled already. I will keep a eye on everything even though i took it for a 40 mile run...just in case.
2006 Limited Edition, 2.4L 4-Cyl DOHC 16V SMPI Engine, Magnesium Pearl Coat Paint, AirAid Intake, NGK Plugs, Crane Wires, Freedom Design Strut Bar, front and rear eibach lowering springs & sway bars:-)
