Old 05 Jun 2003, 05:53 pm
Ian-PT-GT Ian-PT-GT is offline
Dammit!!![xx(]
My Idea has been cracked[}]
I guess I will spill it out[:I]
The Idea is: Install The mopar kit, set it up analize the Boost changes and then, Start the boost adjustments with the electronic boost controller. Now that you get increased fuel flow, you can increase boost slightly if it is bellow the 16 PSI mark.
In my controller I can work with "dutty cycles" at each RPM.
What scares me is if you take it to the dealer, can they flash over the programing and load the factory setting...
Ian
