Re: How do you change a battery in a 2002 Pt Cruiser Turbo?
The battery is located in the front left coner of the engine compartment. If your going to replace it, most shops (Auto Zone, Pep Boys etc.) will change it for you. If you want to do it yourself, take the boxes off that make up the air filter and you'll see the battery underneath. There should be a battery blanket around the battery to keep it away fro excessive heat from the engine.
