06 Feb 2009, 04:39 pm
Re: opinion needed....indded lol
Originally Posted by Mean Green
Why do you say the S3 will work on a PT? Have you seen any S2 or S3 work on a PT. I haven't. The programming is different. It will run, but it won't be the best you can get out of the mod. I'd rather go with a big turbo, supporting mods and the DSP to tune it. That's proven to work. Hell, if the DSP had been around two years ago I wouldn't have gone with S2 on my nsrt.
i wasnt saying to throw it on an auto. but if he had the hardware (turbo, manfold, ect.) and something to tune it with then he could use it. (not the PCM)
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
