Re: WHERE IS THE TRANNY MOUNT????
I removed the tranny mount last night to inspect it on my pt.. and the easiest way to get to it is to remove the airfilter box completely remove the battery/plate under the battery, and then remove the housing that holds the fusebox in place and push it back towards the firewall a couple inches and the tranny mount is right there... as meangreen said... this is probably not the issue as it wasn't with my pt either... i think all 3 passenger side motor mounts went out before the tranny mount went out hahah i already replaced one and ordered the other 2.
