  #17 (permalink)
Old 15 Feb 2009, 04:06 pm
scarrmrcc scarrmrcc is offline
Default Re: HID Conversion Kits
Originally Posted by outfit View Post
I got mine in the other day and hooked it up...Well wouldn't you know it... THE ALL DREADED FLICKER.... To my knowledge this kit and this seller it was not suppose to do it and was a plug in play... My ride is an 06 PT, did yall have to use the power relay kit???? If so where did you get them from??
i was doing some research about "the dreaded flicker" and it seems that is caused by the ballasts using 35w, where the normal bulbs use 55w. it makes the car think the bulb is blown, and it then cuts the power down, creating "flicker" in the ballast.
the only 2 solutions i have found so far are:
get the "non flicker kit" which makes the 35w ballast, use 55w (making the car see 55w)
or get 50-55w ballasts
i am looking at what it takes to make a "non-flicker kit" i work with a few electrical engineers (me being mechanical i have no clue) and might be simple as a small rectifier...easily built with el-chepo parts.
i will update you all tomorrow, when i find out.
