Old 16 Feb 2009, 08:37 am
Gracie512 Gracie512 is offline
Default Re: Ran out of gas and now won't start
Originally Posted by quicksilverdon View Post
When you turn the key to "on" you should hear a humming sound for a bit - that's the fuel pump.
If it died from lack of fuel, the entire gas line was sucked dry, and there's air in it - may take a while to work all the air out.
Yes, I do hear the fuel pump, and it sounds fine, like it always has. When he ran out of gas it was not sitting on flat ground. It was tilted in a ditch. So should I assume that this would cause an even worse air flow problem? I had it towed home and it is now on flat ground.
Any clues how to work this air out?? I have tried to start it everyday for the last week.
This whole thing is just so aggravating to say the least.
Denise
