Old 18 Feb 2009, 12:18 am
TurboMoparDave TurboMoparDave is offline
Default Re: Ran out of gas and now won't start
Originally Posted by Gracie512 View Post
Yes, I do hear the fuel pump, and it sounds fine, like it always has. When he ran out of gas it was not sitting on flat ground. It was tilted in a ditch. So should I assume that this would cause an even worse air flow problem? I had it towed home and it is now on flat ground.
Any clues how to work this air out?? I have tried to start it everyday for the last week.
This whole thing is just so aggravating to say the least.
Denise
How much fuel did you put back in it? Maybe it was sitting at an angle in the ditch that allowed the sump to suck up more fuel than it would have sitting flat. If you only put a gallon or so in it I would try to add some more fuel and see if your luck is any better.
