Re: Transmission Fluid for '02 2.4L Limited Edition...
You should take it to a place with a machine that flushes all the fluid - if you drop the pan, you get less than half - the fluid in the torque converter won't drain.
Use only ATF + 4.
WalMart, I understand, carries it.
