Old 24 Feb 2009, 03:28 pm
chaase chaase is offline
Default Re: clogged catalytic coverter what do i do?
Originally Posted by crusierdad76 View Post
id have to say doing it your self in this case is a lot of work
and you have to have some special tools--OK not really special but---------- a wire feed welder,,,,,, and a plasma cutter,,,,,, and or a cutting torch ,,,,,,,,and or a side grinder ,,,something to remover the old one and make a nice clean line to weld the new on on to
some relaly good sized jack stands and time
well then the ability to used the above mentioned tools
probably cheaper to just have it done
There shouldn't be any welding or cutting involved. Bolts in on one side and a clamp on the other. The universal ones may need that, but there is direct fit ones made for the car.
