Originally Posted by Hooligan
A work to the wise, do NOT run the gas tank below 1/4 as the fuel pump is in the tank and it uses the fuel to keep it cool. Running the tank to empty or close to empty enough times and the tank must be lower to replace the fuel pump. Total cost with labor runs about $300 or so it has been said. You will not get your gas back as they have to drain the tank to do the job.
Thanks I fill when needle hits the first red area and usually by the time the bell goes off.I have estimated mpg based on 1/2 tank reading.- looking like it's a Turbo lite with Mopar blow off valve and a Jet Performance chip. Having the tranny drained and new filter to try and stop the morning hard downshift.
