Old 09 Mar 2009, 01:01 pm
nevinsrt's Avatar
nevinsrt nevinsrt is offline
Default Re: Map Sensor Question
Originally Posted by thunda1216 View Post
well, it would be a throttle body spacer if it was attached to a throttle body, but it isn't. it is between the egr valve and where it attaches, down near the turbocharger.
the plug wires are not stock, they are an oversized aftermarket set similar to the 8.8 mm accel set I have on my harley
ty
i think your refering to the Mopar noise maker.
and what are your plugs gaped at. you may have too big of a gap by the sound of it.
is it throwing a CEL?
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
