Old 18 Mar 2009, 11:42 am
nevinsrt's Avatar
nevinsrt nevinsrt is offline
Default Re: another wasegate question
Originally Posted by turbo_pt2003 View Post
i recently ordered a "vision" wastegate from ebay its suppose to be a knockoff of an AGP type, looks great and price was affordable. but my question is i have a mopar BOV kit and in some of the installs ive seen on the internet they are actually using a blockoff plate insted of that type of BOV.. does anyone have any experience with installing a wastegate and has a BOV kit like mine? any feedback is much appreciated
Thanks, Daniel
the pics your seeing of the install is the person has an aftermarket BOV and installed the plate, lots of people are useing the setup you have and aftermarket BOVs or dual setups like stated above. your BOV setup is fine, just remove the old WGA and install the new one. make sure you have a boost gauge installed in the car before you start adjusting the boost. you dont wanna run lean. if its like the AGP one your gonna want to run a new line from being the turbo to the WGA and remove the plastic stock lines, and your gonna have some part throttle boost.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
