  #14 (permalink)
Old 21 Mar 2009, 02:53 pm
CREWZIN CREWZIN is online now
Default Re: "Check Engine" idiot light on AGAIN
Jaimeg,
your replying to a 6 year old thread, but here's your codes:
P1684 Battery Disconnected in the last 50 Starts
P0601 - PCM internal controller failure.
P1490 (M) Low Speed Fan CTRL Relay Circuit - An open or shorted condition detected in control circuit of the low-speed radiator fan control relay.
P1495 (M) - Leak Detection Pump Solenoid Circuit - An open or shorted condition detected in the Leak Detection Pump (LDP) solenoid circuit.
If the light has been on for a long time. Disconnect the negative battery terminal for about 5 minutes. This will clear all codes. Then reconnect it and drive normally. If the light comes back on, check it right away for the most up to date faullt.
