Originally Posted by JaviPTGT
yeh it just a narrow band but the light dont move it stay on rich what could it be. my friends moves all over the place my dont
You will blow up your engine. That "light show" is not accurate at all and with you fooling the computer about your boost with the MAP clamp you can run lean before the "light show" tries to tell you. You will hear a "boom!" and your engine block will be toast. I've seen holes the size of a golf ball when an engine runs lean. If you are going to run with a MAP clamp you need to do it right and use a wideband a/f gauge. Personally, I wouldn't run with a MAP clamp. There are better ways to increase boost safely.
