Old 23 Mar 2009, 10:31 pm
RoadTramp113 RoadTramp113 is offline
Send a message via Yahoo to RoadTramp113
Talking Re: P0340 cam sensor code in 2006 cruiser
Originally Posted by jbptcruzn View Post
I have a 2002 paperweight in my driveway...HELP....Started with a stall on the highway...Towed by AAA back to house. Ran codes...Got 0340...Changed camshaft sensor...Still not starting....Checked voltage on wiring...OK...Still get code 0340 and now 1193 showed up...I have heard talk of the crankshaft sensor....Should I try that next???...Any ideas on my next plan of attack would be greatly appreciated...
1st thing to try...Disconnect the negative wire from the battery, then, remove the connector from the sensorm then reconnect...might be able to start it and it will last until you get to your mechanic. Unless, of course, you want to change it yourself.
Also, removing the battery connection for over 20 minutes will reset the codes. At least it did in my case.
