Old 04 Apr 2009, 02:42 pm
MX-5 MX-5 is offline
Default Re: speaker issues, wattage of stereo, door speaker replacement issues
The OEM radios have 12 watts rms to each speaker. There is no additional external amplifier. The stock speakers are 4ohms. The OEM radios use a DC bias voltage to raise the negative side of the wiring above chassis ground. The dash speakers are in parallel to the door speakers, and use only a capacitor as a 6db/octave crossover.
Driving high power speakers with a low power amp turned up higher than designed can cause the amp to distort in a method called 'clipping'. This distortion can destroy the system.
