Old 06 Apr 2009, 10:58 pm
02PurplePT 02PurplePT is offline
Default Another front window issue
Sorry if this issue has been discussed before, but a search didn't turn anything up. Here's my issue:
Last year, the front, driver window sometimes would not go down, or if it started to, it wouldn't always fully go down. If it wouldn't go down, I'd usually be able to hear a faint "click" from the window/door (not the switch/dash). Even if it only went part way down, it never had an issue going back up, thank god! As time went on, it happened more frequently and the passenger window now is the same. If one won't work, neither will. However, the back windows have no issues using either the front or rear controls. It's very rare that the front windows will now work and I don't hear the "click" anymore when they won't work. When they are up and I push the switch up, I can still hear the "click" like it's trying to work.
I pulled the switch out of the dash and used some dry air to try and clean off the connectors. I haven't had any luck. Do the experts think it's just the switch in the dash or something more complicated?
If it's any help, the heated driver's seat sometimes won't work. If I push the button on the seat, the orange light will blink a few times and turn off without the seat actually heating up. The passenger's heated seat always works, and there isn't a correlation between the windows/heated seat working or failing.
Thanks for the help!
