Thread: Code P0441
Old 08 Apr 2009, 05:20 am
CREWZIN CREWZIN is offline
Default Re: Code P0441
P0441 Evap Purge Flow Monitor -Insufficient or excessive vapor flow detected during evaporative emission system operation.
A Diagnostic Trouble Code indicates that the Powertrain Control Module has recognized an abnormal condition in the system. DTC's are the results of a system or circuit failure, but do not directly identify the failed component or components.
Possible causes for P0441 include:
Intermittent Condition
Checking Evap Purge Solenoid Functionality
Evap Purge Solenoid Vacuum Supply
You will need a DRB III scan tool and diagnostic manual to troubleshoot the issue.
