Old 22 Apr 2009, 08:56 pm
PT_Cuda PT_Cuda is offline
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Default Re: Oil Dipstick Difference When Changing from Aluminum to Composite Manifold
The little bracket on the tube itself does not line up with the threaded hole for the screw on the plastic manifold if you are trying to use the one from your metal manifold. Easy fix, just get a little "L" bracket or a couple different sizes and a little nut/bolt and make it work.
Or you walk on to any dealership and swipe the VIN off a new turbo and order a dipstick tube for that car.
Its not a big deal either way you are out $5 dollars in parts either way.
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
