Re: Problem with conv top closing
Did you know there is a bypass screw in the top of your trunk that will relieve the pressure so you can lower your top when it has problems without causing damage. It turns counterclockwise all the way till it stops turning to relieve pressure so you can open and close it as necessary. Once the top is in the required position turn it clockwise until seated. 2 N.m or (17 in. lbs.)
This PT Convertible use to be my BABY it was a 2005 Base 5 speed, Black on black on black, Red rims with full moons hubcaps, Amber fog lights, 6 disc indash CD, Polk speakers, Suicide knob, Black 15" spring ant., Gauges in console, APC air filter system, Complete bullet/turbo exhaust system, Hurst Shifter. May its new owner enjoy it as much as we did. We do still have a 2007 Limiter PT in Cool Vanilla with no mods and two HHRs now.
