Old 25 Apr 2009, 08:04 pm
polira polira is offline
Default Re: Something happened
Originally Posted by CREWZIN View Post
Way past time. I cringe when you mention Jiffy Lube, but if your happy with them, Ask or call to see if they have the ATF+4 or the newer synthetic (I think it's ATF+5). They might say they have something that's similar but that'll be up to you if you go threw with it. Anything happens to the transaxle Chrysler's going to go for the type used and use it against you.
You've already seen what being a little low can do to the tranny. Imagine what it would do if you used the wrong type.
Great! Now I know what to do. I'll probably let Jiffy Lube flush the transmission with my next oil change (In about 2,800 more miles) I hope that isn't too long to wait. (We'll see)
As for Jiffy Lube, I've never been to the same Jiffy Lube twice until I moved here to East Meadow on February 1st. This Jiffy Lube is different. They actually vacuum the rugs like they are supposed to they don't try to sell me on things the same annoying way that other Jiffy Lubes have. I've experimented with various Jiffy Lube locations and this is the only location out of the 6 that I have tested where they do all of these things and even explain to you what they are doing and visually show you why they recommend certain things. Also, it's located right in front of Creative Car Wash on Hempstead Turnpike, and they must have some sort of partnership because you get a free exterior car wash with every oil change.
