Old 30 Apr 2009, 11:40 am
nevinsrt's Avatar
nevinsrt nevinsrt is offline
Default Re: Neon SRT Radiator Hoses on PT Cruiser Turbo?
the upper radiator hoses one the SRT and PT are different. the thermostat housing on the SRT is turned 45degs
and the PT is facing stright through the intake manifold.
if you swap thermostat housing the SRT one will sit alot lower and the hose would run into the intake manifold, if you buy the hoses, only the lower one will fit. and the lower one isnt really visible to the eye. if you want a different hose might i suggest.
Custom Made - $199.00 : Killerglass, Hi Performance Glass
they use to have hoses for PT Cruisers but dont anymore after looking. but you can still have one made. the hose is pretty much stright with one 90 deg bend to connect back with the radiator.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
