Originally Posted by johnnypro
Yup, you both nailed it. After adding freon and basically giving up, I jacked up the car yesterday and there it was, a broken connector. I was able to put it back on and the A/C is a flowing!!! Thank YOU both very much!!!!! JP
The first timing belt I did, I did the same thing. Luckily I was able to fix it. If the compressor is unplugged before the repair you won't have a problem. It hits the fan shroud if left plugged it.
