Old 04 May 2009, 09:59 pm
Wienerdog Wienerdog is offline
Default Re: Couple of questions
With regards to the timing belt; Without maintenance records I don't see how you would know the belt had been replaced. If unsure, replace it along with the water pump. I had both replaced when I did the head gasket. Far less expensive than having to replace the belt then the pump. While your at it, replace the serpentine belt too. IMHO. As far as the speaker, start listening to Kenny G.
