Old 05 May 2009, 11:09 pm
garyerrol garyerrol is offline
Default Re: Auxiliary Power Cord
Okay, let's say I got the two power cables routed through the firewall. Now I'm trying to figure out where to attach the positive and negative cables under the hood. Most likely I'm going to be using 8 gauge wire since I have radios to power besides my LED lights. I see a nice ground connector on the drivers side inner fenderwell that I should be able to attach my ground to. I notice I have a post (positive) behind the air cleaner that says to use it for jump starting. Since it is threaded, could I get the correct threaded nut with a couple washers and attach my positive lead here instead of too the battery clamp connector?
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
