Old 17 May 2009, 12:58 pm
ptcruiserdad ptcruiserdad is offline
Default 2001 & 2005 cooling fan issue
my daughters 2001 started running hot yesterday, and after reading many posts here i tested the cooling fan on both the high
and low side with jumper wires, only got a slight movement on one side ,maybe a full revolution, and a plastic rubbing sound. nothing on the other side. i figure the fan is bad. so i decided to check my wifes 2005 to see if fan comes on when a/c is turned on. it did not come on. is it just pure bad luck that now i have to replace fans on both PTs ? or is there something else i can check on my wifes 2005 ?
