Re: locked doors
Problem solved, the locks were just plain stuck. I removed the door panels (they do come out w/ the doors closed). I then shot white spray lithium grease into the latch mechanism then forced the lock rod back & forth, then it finally unlocked. The other side was more stubborn. After getting the door open it would not latch. I had to unbolt the latch mechanism and lube it up. It now works w/ the only problem being the child lock being stuck on. I can live w/ that. Thanks to all who took the time to respond.
