The bolt goes into a big cast iron mount on the front of the engine. Take off the upper and lower motor mounts, disconnect the a/c compressor electrical connector and you will be surprised how far up you can jack the motor. Just watch out for the alternator bracket hitting the a/c drier on the backside. You could also take it off the motor by removing camshaft cover, power steering bolts and 3 bolts hold it to the block.
