Old 19 May 2009, 04:01 pm
dpmeeks dpmeeks is offline
Default after timing belt idles rough
I took the wifeys 02' PT limited 127k miles,up to the local shop and had them put in a new timing belt, idlers, drive belts, and water pump. The guy said he found a vac hose broke he replaced.
( After ) picking the car up when in drive at idle or just park idle the engine shakes, more noticeable in gear. When you give it gas and go the car has plenty of power and runs fine. It idled fine b4 the above work was done.
I thought maybe it needed a tune-up so i put in new plugs and wires and no change. It did need a tune up though, the plugs looked pretty bad.
It looks like they disconnected the battery cuz the clock time is wrong. Does the computer have to reset itself ? I stopped by autozone and they checked for codes and none found
Any Ideas what could have happened ?????
2001 PT Limited
