06 pt (A/C) leaking lots of water from the firewall at the ac inlet to interior
hi everyone
if this question has been answered i apologize in advance, but i have search this forum for the answer and found none--
yea A/C issue---the ac works fine and cold on all fan setting at first --but after awhile (10 min or so) the air slowly stops coming out at low speed but still cold--i crank the fan up all the way and and in a second it will blow again but with little particles or water drops or mist or....? (no smell) starts to come out of the vents still cold.
like its blowing out some kind of clog (no a/c vent installed) and then the low setting will work fine for a little more --then i have to repeat and so on...
when i open the hood and follow the source of the water drips (allot of drainage)from the ground up it appears to be coming from where the ac hoses go into the firewall and to the inside the car --just flowing off the collection of hoses there and onto the ground, not inside-- only outside.
this has been going on for a month or so
its like something in the system is clogging.
if the a/c button is not pushed it doesn't seem to happen
