Old 20 May 2009, 09:46 pm
slartyblarfast slartyblarfast is offline
Default Re: 06 pt (A/C) leaking lots of water from the firewall at the ac inlet to interior
More than likely your a/c system is low on freon. The evaporator is freezing up and when you turn it on high it blows the ice off. Take it to your dealer or a shop you trust and have them check the charge. Typically it's the hose from the condensor to the evaporator that leaks.
