They should just pop off, no screws use to hold them. You may want to get what is called a trim stick, so as not to mare the finish or bend the plastic. I have use old toothbrushes as a trim stick, just trim down the handle end to where it is a good pry bar tip that will fit under the trim you want to remove.
