Ok... the best way to bleed brakes is to have one person press on the pedal and hold it. You crack the bleeder open and let the fluid run out. When it stops the person pressing the brake lets up anjd pump the pedal 2 or 3 times and press and hold. Do this till there are no air bubbles in the fluid coming out. Be sure and don't let the master cylinder get low. If it sucks air then..... well it gets to be a real pain after that!
