Originally Posted by slartyblarfast
Most likely your problem is the clutch cycling switch which is on the accumulator. It's probably stuck closed which is allowing it to freeze up.
I'm pretty sure that your "Clutch Cycling Switch" is the same as my "High Pressure Switch".
